I've just installed my sub (10" ported tube, very pleased with the sound) and it seems to be working great except, every once in a while I try to start the car and it won't start. hmmm. The security light comes on (it never had in the past). Unplugging the amp resolves the problem. Why does my car think I'm trying to steal it?
security?
Re: security?
Originally posted by 96firebird311 View PostOdd. I think most people have this issue when their VATS chip is dirty or damaged.
Power ran directly from the battery? Where is the remote turn on lead tapped? And I assume just grounded to the chassis somewhere in the back... no?
Re: security?
You're running your main power wire for this sub from that skinny 18awg cig lighter wire? Let's slow down and think about this. Did you notice how the power/ground wires coming from the sub were much thicker than the cig lighter wires? This is because the bass tube pulls much more current than the cig lighter. It is designed to be run directly off the battery. A cheap 8awg amp kit is very cheap online. Here ya go.
http://www.knukonceptz.com/productDe...?prodID=KLM-K8
Re: security?
Originally posted by 96firebird311 View PostYou're running your main power wire for this sub from that skinny 18awg cig lighter wire? Let's slow down and think about this. Did you notice how the power/ground wires coming from the sub were much thicker than the cig lighter wires? This is because the bass tube pulls much more current than the cig lighter. It is designed to be run directly off the battery. A cheap 8awg amp kit is very cheap online. Here ya go.
http://www.knukonceptz.com/productDe...?prodID=KLM-K8Last edited by zpwn06; 09-18-2008, 11:54 PM.
