Stock Speakers - FirebirdV6.com/CamaroV6.com Message Board
Stock Speakers
  • Stock Speakers
    I have a 96 firebird with the cd, equilizer, and 10 speakers. i was wondering what are the best,cheapest replacement speakers for the doors and cheapest subs i can get that replace the factory subs and fit in the factory holes.
    Re: Stock Speakers
    10? two doors, two tweeters, two in back...where are the rest? I have a 2000 monsoon and thats all I got...
      Re: Stock Speakers
      nevermind. It was an option apparently. but just curious...where are they? two in the hatch. two...where?
        Re: Stock Speakers
        i have the monsoon system, and i have 2 in the hatch, two on the sail panels, and two in the doors
          Re: Stock Speakers
          http://www.keeaudio.com/id72.html
          Those Audiopipe subs would work for your sail panels. The brand isn't the best, but you don't have a lot to choose from when integrating with the Monsoon system. I would email Ian (owner of the site) and ensure that those subs and dual 4 ohm. Since it doesn't really say in the description.
          The fronts are much easier.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
            Re: Stock Speakers
            the speakers in the hatch are not one speaker. theres a 4 inch with a seperate tweeter. so i theres actually 4 in the hatch 4 total in the doors and 2 in the sail but i dont have the monsoon so i dont know if thats different
              Re: Stock Speakers
              ok thanks for the help
                Re: Stock Speakers
                ian's a good guy, i talked with him when i was setting up my current front stage... even though i ended up not buying anything off him, he still gave me advice.
                2000 Camaro 3800 A4
                  Re: Stock Speakers
                  ok i have a 01 camaro and it has the monsoon also i had 6.5's in the front with a "seperate" tweeter thats not so separate.. the sails have the 6.5 "subs" and the rear is a pair of 4 ohm coaxials i found this to be weird and figured there should be components there also!!! that is what was stock. Any ways heres what i did..... front stage, mb quart components 6.5- I took the rear speaker wires and ran them to the sails and installed another set of mb quart components there also.. i then ran the "sub" wires to the back and put in a "cubby" box with a boston pro 10.5 sub in it dvc4 and just wired it straight in!!!! the4 sound is something amazing and is enough to piss off the neighbors lol Just thought id throw this out there maybe someone may like the idea also
