Hey I was trying to put some new speakers into my camaro but the manufactor of the speakers didn't give me enough of those hook up things. So can I just strip the wire and twist or solder it onto the positive and negative prongs from the speaker? And when I replace the stock speakers on my 94 Camaro do I have to remove the door panel or can I take them out of the door? I tried it and it seemed kind of hard,but maybe you guys have a better I way of doing it
Speaker Hook-up Questions
Re: Speaker Hook-up Questions
Wal-Mart sells electrical tape for like .81 cents a roll. It's not top quality stuff, but it's miles better than your ghetto-rific masking tape idea. Crimp on some connectors and then connect to your speakers. Remember, if you cut corners, you'll just be tearing it apart again to fix your mistake. Save yourself some time and take the extra 10 minutes the first time around.
Originally posted by 96firebird311 View PostWal-Mart sells electrical tape for like .81 cents a roll. It's not top quality stuff, but it's miles better than your ghetto-rific masking tape idea. Crimp on some connectors and then connect to your speakers. Remember, if you cut corners, you'll just be tearing it apart again to fix your mistake. Save yourself some time and take the extra 10 minutes the first time around.
truth, im pretty sure masking tape will be dangerous to use anyways, just do it right so you dont have to go back and do it over
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
