Blown speakers - FirebirdV6.com/CamaroV6.com Message Board
Blown speakers
  • Blown speakers
    Hi, I looked at the sticky but it is old and don't know if those speakers are made anymore.
    Anyways, i got some blown 6 inch speakers- both the ones next to the bucket seats in the back. I found a wrecked TA and took those out, and they blew out too.
    What are good replacements that are currently made and will they sound good with the monsoon setup? Will i have to splice some wires due the 4 wires coming off the harness or can i get speakers that have 4 tabs to them?
    2000 M5 SILVER FIREBIRD<br />*Flowmaster 80<br />*K&N air filter<br />*SLP LCAs<br />*Fast Toys CAI
    Re: Blown speakers
    Don't know about the monsoon setup, but Crutchfield currently has some good specials (getting rid of the older stuff) on 6 1/2. Pair of Infinity Kappa or Polk/MOMO are like $60. Those are both the higher end of their respective speaker lines.
      Re: Blown speakers
      http://www.keeaudio.com/id72.html
      Bazooka 6.5" Dual 4 ohm subs. Best match for the Monsoon system and the best buy for the money.
      And I'd love to update our FAQ threads..... but I voluntarily gave up my moderator status a couple years back when I sold my F-body. Didn't think I'd post on this board much more..... but it's habit now. LOL
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Re: Blown speakers
        Thanks. Do those have four tab contactor things that you solder the wire to or just two? I'd probably just take it somewhere to have it done but how hard would it be to do it myself?
          Re: Blown speakers
          Very easy. And yes on the 4 connections. Just like the factory speakers. 2 PAIR of + and -.
          Here's is the pin out for the Monsoon amp on the Firebird. Should help you with your wire coloring at the speakers:
          E1 - DARK GREEN - right front speaker negative input
          E2 - GRAY - left front speaker negative input
          E3 - TAN - left front speaker positive input
          E4 - DARK BLUE - right rear speaker positive input
          E5 - LIGHT BLUE - right rear speaker negative input
          E6 - YELLOW - left rear speaker negative input
          E7 - BROWN - left rear speaker positive input
          E8 - BLACK - ground
          E9 - BLACK - ground
          E10 - not used
          E11 - ORANGE - fused input feed
          E12 - ORANGE - fused input feed
          E13 - WHITE - left rear subwoofer negative output
          E14 - TAN - left rear subwoofer positive output
          E15 - DARK BLUE - left front speaker midrange positive output
          E16 - LIGHT BLUE - left front speaker midrange negative output
          F1 - LIGHT GREEN - right front speaker positive input
          F2 - TAN - right rear subwoofer negative output
          F3 - RED - right rear subwoofer positive output
          F4 - LIGHT BLUE w/BLACK - right rear subwoofer speaker negative output
          F5 - DARK GREEN - right rear subwoofer speaker positive output
          F6 - DARK GREEN - right front speaker midrange negative output
          F7 - ORANGE - right front speaker midrange positive output
          F8 - not used
          F9 - not used
          F10 - LIGHT GREEN w/BLACK - left rear subwoofer speaker negative output
          F11 - DARK BLUE w/WHITE - left rear subwoofer speaker positive output
          F12 - not used
          F13 - GRAY - right rear midrange speaker negative output
          F14 - WHITE - right rear midrange speaker positive output
          F15 - RED - left rear midrange speaker positive output
          F16 - PURPLE - left rear midrange speaker negative output
          The only ones you need worry your pretty little head over are:
          LEFT REAR SUB
          AND
          RIGHT REAR SUB
          Put each above pair of + and - to a single voice coil on the Bazookas. In other words, DO NOT connect white(E13) on one negative and attempt to use dark blue/white (F11) on the corresponding positive. Get it? Keep your pairs together. It's really very easy. I could easily have this done in 30 minutes including soldering. The rear speaker grills come off.
          Red 96' A4 Firebird
          Check it out here!
            Re: Blown speakers
            You are awesome. Thanks for all the help- it's very much appreciated
