Asking for an update from 96firebird311 (plz) - FirebirdV6.com/CamaroV6.com Message Board
  • Asking for an update from 96firebird311 (plz)
    back in october i asked you about replacement speakers and you recommended some polk audio ones. I just wanted to ask if that since then have you found any better ones at around that price range? Also could i install component speakers because idk if it matters since its non-monsoon and all. Thanks and sorry to bother
    Re: Asking for an update from 96firebird311 (plz)
    Hey no problem. In my opinion, the Polk dB series sounds better than most in that price range. (Kicker included) I've also had plenty of time with the Alpine Type-S line and I wasn't impressed. If you're buying 2 pair, the Polks are $75/pair. Hard to beat for that price.
    The entire audio system is stock in your firebird at this time? If so, and you plan on keeping it mostly stock, I wouldn't bother with a component set. In fact, it's actually against Illinois law to power a Polk component set off a factory headunit. Dead serious! Look it up!
    If you plan on using an aftermarket amp in the future, go for the component set now.
    Above all, see for yourself. Hop on by your local circuit citys and best buys and give a listen. Bring your own CD and try to use the same headunit for all your tests. Check the EQ settings as well, as this could EASILY sway your decisions.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      thanks a lot, its because im on ebay right now and i found those speakers you mentioned before and found them for 50-80 a pair so ill be ordering them soon. You have any good head units that you would reccommend under $200? Why is it illegal? that is something i have to look into.
        /**wat
          also, I've been looking at some boston acoustics for my door speakers on my bird. Are they a decent buy? hard to tell. I've liked all the BA I've had in the past
            would the 6-1/2" speaker work? the ones you recommended before were that size but this one guys telling me they need to be 6-3/4"?
            hes telling me to get these instead (any good?):
            http://cgi.ebay.com/ws/eBayISAPI.dll...0%3D%26fvi%3D1
              Just wait until a cop pulls you over and finds out you're powering a Polk component set off the headunit. Oh boy! You're gonna get it! (I kid. Just proving a point guys. LOL!)
              6.5" and 6.75" will both fit without any modifications. Most manufacturers don't even make a 6.75" speaker. In this biz, they're considered interchangeable sizes.
              And those are obviously the same speakers, just in the 6.75" size. Go for it.
              Boston makes decent stuff, but I don't have much experience with their car audio equipment. Just home audio.
              As for your headunit:
              http://www.crutchfield.com/p_130DEHP...-P5000UB.html?
              6-channel 4V RCAs, 2-line display, and USB. Awesome headunit for the price.
              And if you still have the stock headunit, that's the best deal on the Pioneer too. You can find it on eBay for $145, but crutchfield includes all the installation equipment for free. They're also an authorized Pioneer dealer, so you'll get full warranty if needed. If you already have an aftermarket headunit, then you have all the parts already. Just buy it off eBay.
              Red 96' A4 Firebird
              Check it out here!
                this head unit will go well with the speakers i assume (since you're the expert). You've always been a great help, thanks
                  I've installed no less than 200 of these. Quality unit.
                  Red 96' A4 Firebird
                  Check it out here!
                    thanks a lot, my last question is if this speaker harness will work?
                    http://www.scosche.com/products/productID/1249
                      I don't recall if you had the monsoon system or not. Nor do I really recall what the speaker connections looked like. Regardless, I wouldn't waste your money on those. Just splice the wire's insulation back a little bit and connect your own wire. No need to cut off the plug.
                      I do it all day, every day.
                      If you're really super lazy and want to waste the money, buy them from a local store. If they're the wrong ones, return them.
                      Red 96' A4 Firebird
                      Check it out here!
                        smart man....thanks i'll do it that way and save myself 20 bucks. thanks again man, i might have to start paying you for this advice.lol
                          After nearly 8 years of giving advice on this board alone..... I think I'm due part ownership. LOL
                          Red 96' A4 Firebird
                          Check it out here!
                            agreed!
                              Nah, you still got a few more years before that :). Plus, you must own an F-Body :P
                              ~97 3.8L V6 Camaro~
                              A few things
                              Only Member of Team Hooker?!?
