Putting door panel back on 2000 Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • Putting door panel back on 2000 Camaro
    I spent about 7 hours in two days putting new woofers in the doors. I see lots of instructions on tearing the door panel off and nothing about how to put it back on.
    I have one door on but the locking slide (red slide ) is a ***** to put on and I wonder if anyone knows the way to do it.
    Taking the door off is easy, no instructions needed but putting it back on is
    horrible.
    Phil
    Re: Putting door panel back on 2000 Camaro
    Well if you've taken the panel off, then you know you must lift UP then out to remove it. Obviously you'll have to do the opposite when putting it back on. Position the door panel a little higher then where it normally sits. Ensure all the plastic "hooks" or "tabs" are in position over their respective door panel hole. Hold one hand at the top of the door panel and one towards the bottom to help keep the door panel flat against the door. Push down. Ensure the top part of the door panel is clipping around the window area. That part really has to sit into place for the door panel to go on at all.
    As for clipping the door lock clip back in place, some people really seem to have a hard time with it. I don't know why I never did. Pull the wire into the out (or unlock) position. Line up the hole in the tip of the clip with the pointed wire end. Give it a solid push straight in to clip it onto the wire.
    Don't know what else I can tell you man. Hope this helps.:o
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      put the red lock slide on after you put the panel on. pretty easy from there like bird 311 said.
        Yeap, pull it out to the unlock position. Then slide it in, and push the wire into the hole.
        Put the panel on first.
        Try not to break the tabs, that just sucks.
          yeah, putting the door pannel back on is a pain in the @$$, ive gone thru 2 sets of speakers, all the way around... imagine my pain
            just got a brand spanking new set of ebony leather panels for mine... putting them on this weekend...
