Q logic kick panels - FirebirdV6.com/CamaroV6.com Message Board
Q logic kick panels
  • Q logic kick panels
    has anyone had any experience with these im thinking i have 4 spoeakers powered by an external amp, might as well use the ones powered by the head unit so i would like to add another two components to the front. has anyone used q logic kick panels made for our cars with sucess
    Re: Q logic kick panels
    I just noticed some of these on Crutchfield the other day. Wasn't sure what to think of them. Quality and fitment would be my two concerns.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      Not Q logic kick panels.... but custom ones I made them for $30
        impressive considering they want about 190$ for these things, how did you go about fabbing this up, i am intrigued
          I have heard they are flimsy and large. If you drive a stick, I'd avoid them for sure.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
            i don't recommend these... i had a pair in my camaro... you actually have to cut your old kick panels because they aren't the full size... and yes they are flimsy... on the driver side, you have no where to put ur left foot but straight down, which makes it very annoying... i have a pair in my garage just sitting there because i took them out and replaced with new stock kick panels.....
              thanks for the advice, not going to go with these anymore, but what can be some ideas for adding more speakers.
                A properly installed quality component set powered by 150WRMS should be enough to completely rock ANYONE'S socks off. There is no reason to ghetto up your car by squeezing as many co- and tri-axils into it as you can.
                You want louder? Buy a bigger amp.
                Red 96' A4 Firebird
                Check it out here!
                  I have 1000rms on the hi's.... and I always want it louder...
                    Somehow I doubt that...:poke:
                    Red 96' A4 Firebird
                    Check it out here!
                      i doubt that too...
                      i havent been around much in the past year, but anyone who knows me and stereos.......
                      i used to have two 18's in the camaro pushing over 3000 watts RMS.... if i didnt have a massive cap and a 2nd battery... my car would stall at idle while using the stereo as it didnt have enough power to create a spark... ;-)
                      i gave up the 18's to my brother last month... im going for a cleaner two 12 install...... i have spent about 1500 on the camaros interior in the past month bringing it back to brand new, with brand new oem parts...... i haven't driven it on the road in over a year, and i miss it.......
                        no.... its 1000rms .... and 3600rms on 3 12" subs... :dj:
                          Originally posted by Big Tymer View Post
                          i doubt that too...
                          i used to have two 18's in the camaro pushing over 3000 watts RMS.... if i didnt have a massive cap and a 2nd battery.... ;-)
                          I used... 200amp alternator ... 2 Kinetik Batteries ... 30 Farad Cap ... 3 150A Circuit Breakers....
                            Regardless, I stand by my statement.
                            Pics? System specs?
                            Red 96' A4 Firebird
                            Check it out here!
                              by you saying "1,000 rms on the hi's" that means your tweeters are getting 1,000 watts so what are your other speakers getting(the mids[unless you just have subs and tweeters]) maybe that is why everybody is saying they doubt it. plus normally when giving numbers for a sound system you do not give totals because nobody cares. you give a number like "my componet sets are getting 150 rms each"
