PERFECT spksr for Monsoon Sytem - FirebirdV6.com/CamaroV6.com Message Board
  • PERFECT spksr for Monsoon Sytem
    Wanting to avoid all the problems involved with adding amps ...get them to turn on and off with the radio etc. I found a great solution. I bought the 2 ohm system by Cadence TXC6K
    system. The woofer goes in the same place as the GM woofer. I had the tweeters
    mounted about 18" above the woofer on the door. They drilled a hole and mounted it flush.
    The crossover included is not necessary as the crossover is built-into the Monsoon so you
    just connect the wires to the woofer and disconnect the wires to the tweeter located
    inside the woofer and run those to the new tweeter. I could not be more pleased
    with the bass and high-end. No rattle....
    Finally a solution.
    Phil
