any way to add a sub to my monsoon system do I need seperate amp I have a kicker comp vr did not know if I needed seperate amp where to wire through thanks for any help
adding sub to monsoon
Re: adding sub to monsoon
Yes. You must have another amp.
I'd purchase a line output converter, use it to tap into the sail panel (rear seat) speakers, and then run your RCAs to your aftermarket amp.
You'll need this wiring kit if the amp is more than, say 500W RMS
http://www.knukonceptz.com/productDe...?prodID=KLM-K4
If it's only 200-300W RMS and you never plan on upgrading to a larger amp or adding a second amp, you can safely use this one
http://www.knukonceptz.com/productDe...?prodID=KLM-K8
An inexpensive way would be to disconnect one or both speakers on each side of the
rear seat....then buy some 2 ohm woofers of 8" or less. Mount them on the shelf
that lifts up in the back....run the wire to those woofers. You will need to do an internet search for the woofers.
See this: its on sale and there won't be any cutting.
http://www.parts-express.com/pe/show...gn=email073009
