adding sub to monsoon - FirebirdV6.com/CamaroV6.com Message Board
  • adding sub to monsoon
    any way to add a sub to my monsoon system do I need seperate amp I have a kicker comp vr did not know if I needed seperate amp where to wire through thanks for any help
    Re: adding sub to monsoon
    http://mods.firebirdv6.com/stereo.html#FBAQ_6
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Yes. You must have another amp.
      I'd purchase a line output converter, use it to tap into the sail panel (rear seat) speakers, and then run your RCAs to your aftermarket amp.
      You'll need this wiring kit if the amp is more than, say 500W RMS
      http://www.knukonceptz.com/productDe...?prodID=KLM-K4
      If it's only 200-300W RMS and you never plan on upgrading to a larger amp or adding a second amp, you can safely use this one
      http://www.knukonceptz.com/productDe...?prodID=KLM-K8
      Red 96' A4 Firebird
      Check it out here!
        An inexpensive way would be to disconnect one or both speakers on each side of the
        rear seat....then buy some 2 ohm woofers of 8" or less. Mount them on the shelf
        that lifts up in the back....run the wire to those woofers. You will need to do an internet search for the woofers.
          ^^^^yeah or he could do what he asked about and add the woofer he allready has using 96firebird311's advise... either way would work i guess:rolleyes:
            thanks for your guys info. gives me a couple options which is what I wanted
              See this: its on sale and there won't be any cutting.
              http://www.parts-express.com/pe/show...gn=email073009
