I found a complete LS1 suspension package, my question is, A. does this fit up w/the v6s suspension?? B. is it worth upgrading?
LS1 Suspension
Re: LS1 Suspension
What parts for the suspension , because the V6 and V8 have mostly the same suspension unless its a 1LE model.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: LS1 Suspension
^ True , just get some LCA's ,SFC, panhard rod?, shocks and maybe springs. Then your suspension will almost be new, but then you will have to look at the front lower/upper A arm bushing, Trans mount, TQ arm mount, sway bar bushings/endlinks and tie end rods.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: LS1 Suspension
Upgrading to ls1 suspension is kinda pointless imo. Won't gain anything like said above its the same pieces. The v8 spings will make u sit higher an give u more of a 4x4 look. Use the money for some tubular lcas and phb like said above.
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
Re: LS1 Suspension
Originally posted by ssms5411 View PostWhat parts for the suspension , because the V6 and V8 have mostly the same suspension unless its a 1LE model.
98 and newer (LS1) cars use the same suspension and brakes as the V6 with the exception of front spring rate. The only differences are the harder bushings use in the 1LE and WS6 cars. The 1LE and WS6 also used stiffer springs than the other V8 cars. Did the OP read anything in the tech database on the web page?sigpic
Re: LS1 Suspension
The 1LE front upper /lower A arms are beefer/weigh more along with the LCA's and Panhardrod and springs /shocks. I searched the 1LE site and found alot of info on 1LE stuff, thats why I have 1LE rear springs, their progessive stock height springs 130LBS-170LBS with heater hose mod already done. Brian I fon't think hardy anyone reads the data bases or searches, becuase all the answers are there. Thats how I chose the 1LE springs, plus they were new. Sway bars are all over the place , off of SS's or WS6's 32/19 setup's.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: LS1 Suspension
Needs to be a SS or WS6 to get the 32mm hollow front and 19 solid rear, yes the shocks will be decarbons on the LS1 most likely, so better to look for aftermarket shocks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: LS1 Suspension
Look in the Tech database it has alot of info on our 3800's also modification lists.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
