has anyone removed the electronic brake control module before? i see 1 bolt at the front; what else is holding it down? the torx screws? i referred to my service manual, but it said at the time of that printing, the ABS supplemental information was not available.
Brain farted. I didn't see the slot that it slipped into. All you need to do to remove it is unbolt that bolt in the front, disconnect the electrical connections, and disconnect the brake lines with 12mm and 14mm box wrenches.
Glad I could help I sent it through my mind to ya, your welcome. LOL Glad you figured it out.
