Anyone know what the brake line diameter on a 97 camaro is? I measured 5mm and just want to be sure I'm right. And does anyone know where to find a diagram for the brake lines for my car?
Brake line size
Re: Brake line size
Actual line diameter shouldn't matter as much as the connector thread and size. At the autopart stores, if you buy a pre-cut length of brake line, the import ones rather than domestic worked on my car, which would be the same setup as you have. What specifically are you looking to do?
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...15 hours ago
