hard rubber or poly bushings? - FirebirdV6.com/CamaroV6.com Message Board
  • hard rubber or poly bushings?
    How's it goin y'all??? I plan on buying the UMI lca/panhard bar combo from LMPerformance.com this week, and I wanted to get hard rubber bushings in each. My question is this, Suspension Techniques has a 35mm front sway bar that I want and it has poly bushings on its end links. Should I get hard rubber or just stay with the poly. If I stay with the poly, will there be any bind issues, or is that just a problem with poly lca bushings??? Thanks. If this is a stupid question let me know, I've never done any suspension on cars only trucks.
    1997 Chevrolet Camaro
    L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
    Re: hard rubber or poly bushings?
    I would stay with poly, I have a ST35mm sway with poly busings and endlinks sitting on my garage floor , if your interested, PM me.
      If its a daily driver take the hard rubber,poly sqeaks over time,plus it doesn't wear as well.
        My poly suspension doesn't squeak and thats from tub. K , upper/lower A arms and TQ arm to LCA's panhardrod,tans mount and sway bars. Just grease them twice a year like rubber and they will last a lifetime, some of mine are 11 years old. Rubber will over time crack and start to fall apart.
          3 piece Polyballs... that is all.
          Lounge Moderator
