going from bilstein and 1LE to eibach - FirebirdV6.com/CamaroV6.com Message Board
  • going from bilstein and 1LE to eibach
    So I have a set of eibach v6 springs in my garage still in the box, they are the less aggressvie 1 inch drop. I can't remember exactly what they were called.
    Right now I'm running some bilsteins I installed in 04 along with a set of v8 1LE springs. The springs have ruined 2 sets of tires. Even with a proper alignment the outside of both tires are wearing pretty badly. As best as I can figure is that I just have too much spring/shock and nothing is compressing enough causing the tire to take the load.
    So my question is, anyoneone running this combo, eibachs with bilstiens?
    -Brad
    2000 V-Star Custom 1100
    :rock:
    Re: going from bilstein and 1LE to eibach
    nope.
    but if you want a set up that will work talk to sam strano. He can get you what you want and will make it work.
      I have 1LE springs in the rear with Blisteins, no problem, QA-1's up front with 300 lb springs and no problems, I'm looking for a front set of 1LE's.
