Sub Frame Connector weight comparison - FirebirdV6.com/CamaroV6.com Message Board
  • Sub Frame Connector weight comparison
    I was looking for this information and could not find it so i figured i would compile it and hopefully help someone else out!
    UMI Performance
    umiperformance.com
    Boxed Version # 2000 - 27.25lbs (2") $159.00
    Tubular Version # 2001-2002 - 24.75lbs (1.750”) $139.00-174.00
    #2003 & #2004 they said "about" 30lbs (1.250”) $279.00-299.00
    BMR Fabrication
    bmrfabrication.com
    SFC001 boxed connectors - 26lbs (2") $159.00
    SFC004 tubular - 15lbs (1.625") $139.99
    J&M Products
    hotpart.com
    2 point tubular - 18lbs (1.750") $137.50
    3 point boxed - 38lbs (size not listed) $194.55
    all 3 companies i have talked to have been really nice and honest and say 3 point is a waste of money.. they would for sure use 2 point its not worth the added weight.
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: Sub Frame Connector weight comparison
    Good info. From what I've heard, SLP 3-points are some of the heaviest SFCs. Kenny Brown DD's were also pretty popular back in the day, and are similar to the J&M design. As for the 2-point vs. 3-point, most people are fine with 2-point. 3-point connects are useful when using a shorter tunnel brace mounted Torque Arm.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      updated with pricing and thickness if anyone has any other brands with for sure weights or anything they would like to add to the main post pm me and i will add it :)
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        Awesome. I was looking at 3 point but I guess 2 point will be good enough. Thanks for the comparisons.\
        Next up should be how effective each brand is.
          I have the UMI tubular weld on version on my 99 'vert and they made a world of difference as the car feels solid now, before the SFC install, my car was kinda noisy with a shaky/mushy feel when pushed hard. Now, burnouts are much easier, especially around corners where the car just drifts for a bit and then hooks (predictably) ...so much fun! Cornering is greatly improved and very solid/tight on rough roads. Best 1st mod for a convertible, almost no cowl shake any more.
          I strongly recommend this mod as it greatly increases frame rigidity (GM should have built 4th gen F-bodies with SFC to begin with). I paid $210 for the SFC set and another $50 to have them welded in. My mechanic said all that welding smoked out the shop but am I ever glad he did it right. This mod is worth every cent I paid :cool:
            You're making me want to spend money:tup:.
              same.. ive always wanted SFCs but i thought they were alot more. this is gunna be hard to resist..
              1999 v6 Camaro M5
              Automatic to Manual converted
              Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
              !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
                i am going with the j & m 2 point i have their panhard bar and lower control arms and love them..
                2001 Camaro 3.8 A4
                1991 3000GT VR4
                  Good mod. I couldnt resist the 3 point connectors. Especially since I was welding my cage hoop to them.
                    i have 2 point tubular j&m sfc's (weld in) and they are by far one of the best suspension mods i could have done. along with my other suspension goodies, the car takes twisties like it's on rails---my 3.8 handles better than my ls1 no questions asked.
                    vr4--ur in good shape mang.
                    pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
                    gone in body, but not in spirit
                      do your 2point since they are round still make good jacking rails?
                      2001 Camaro 3.8 A4
                      1991 3000GT VR4
                        I have the 2 point Tub. BMR's sub frame connectors which are nice , bolted them in, then welded them. Great handling and really notice them once driving. I use the jacks on the tub. part for the jacks come in handy.
                          techsan23, you have one of the cleanest under carriages I have ever seen...not only that, but it appears that your car is set up right too. Please tell me what your car has going on, it looks serious enough :bowdown:
                            yeah they still serve as good jack points
                              The easiest way to see most of my engine mods is in my for sale thread L36 part out. I spun a cam bearing not too long ago :( A couple of things I am hanging onto right now include the powerdyne supercharger, injectors, hp tuners and methanol injection. I will update sometime on how my LQ4 swap is going, but I dont want to deviate too far from the v6 theme of the site.
