I recently put new springs and shocks on my car but on the rear the right side is like an inch or 2 higher than the right side. any ideas? i'm planning on lca relocation brackets and new lca's, will that fix my problem?
uneven rear end
Re: uneven rear end
These cars are going to sit a little lower on the passenger side. Supposedly it's to offset the weight of the driver. It's even more noticeable on a worn stock suspension or new suspension. Now a normal difference is going to be between a 1/4-1/2", maybe even 3/4" in some. But anything over an inch is going to be something else.
If it's more than an inch, try getting more exact measurements and posting them up.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Re: uneven rear end
whoa, i dont have my shocks and springs done, but that gap on the passenger rear is way too big? thats like what two inches? have you measured it?
Re: uneven rear end
Originally posted by jeffyp32 View Postno i havent measured it but to me it looks about 2 in too
Re: uneven rear end
Take some pictures with your car on even pavement. It's sitting on grass and looks like there might be a bit of a downhill slope on the driver's side. I had a guy install my rear shocks/springs and when I first saw it I couldn't fit but one finger between the tire and body on one side and my whole hand on the other. Moved it to some even ground and it sat fairly level.'99 Camaro
'04 Saab 9-3 Aero
Re: uneven rear end
Im gunna guess the perch as well on one side...make sure you got a perch on both sides...Did you get two different size springs? (sounds dumb yes, but hey, you ever get two right shoes in a shoe box? They mess up parts sometimes, so you never know)
Thats what comes to my mind first. Do you have any other aftermarket suspension mods?
Re: uneven rear end
Originally posted by TheGr8Schlotzky View PostIt almost looks like you forgot the spring perch on one side. That is a huge difference.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...16 hours ago
