what would happen if... - FirebirdV6.com/CamaroV6.com Message Board
  • what would happen if...
    i use a 17.5mm swaybar bushing on a 17mm swaybar?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: what would happen if...
    Might get play when cornering since its not tighten down, so I would think your endlinks to take most of the weight and might break more often. You could try and fill the outside of the bushing with gasket maker/ silicone and let it dry and see if will make up for the difference. Just don't do the inside since thats wear the bar is and wear the grease will go. I'm sure gasket maker on the outside the back of the bushing should make up the difference so you don't have to buy another set.
      i can get a 16mm bushing and have a machine shop hone it out to 17mm i may just go that route to be safe.. just trying to get it done a little quicker.
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        I would do the 16 and hone it out ,sounds alot better and safer.
