Hey everyone. I'm about to start upgrading my suspension, and I want new springs but don't want to lower the car. I was looking on sumittracing.com and found some moog springs that are stock height replacement. The front are 290 pounds/inch and the rears are 104 pounds/inch. Will these give the car a lifted look? I was looking in the tech database and is says the front rate is 223 pounds, and the rear is 95.5. I know it says stock replacement, but I just want to be sure. Thanks guys.
springs question
Re: springs question
Would these be an ok choice for my setup with a 35/19 swaybar combo? I just ordered a 19mm rear sway off ebay but I don't want to install it till I get my springs set up properly.1997 Chevrolet Camaro
Should be stock height or maybe alittle more. But not too much I wouldn't think.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I was going off FirebirdGTs setup with 351 front, and 80/137 rear. I just don't want to lower the car to get springs that stiff. The roads here aren't the best.Last edited by espey_16; 03-16-2012, 01:36 PM.1997 Chevrolet Camaro
I run 1LE rear springs 130-170 progessive rate and it didn't jack the rear up as high than I thought it was, actually gave it a good stance.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Do you think it'll look alright with stock 16" wheels and tires?1997 Chevrolet Camaro
Hard to tell, just have to try them and find out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I bought the SLP shock/spring package, and I love it. It's certainly a stiff ride, but it's not unbearable. One of the things that helped me choose that package was that it didn't really lower the car. I think it's like 1/2 inch in front and 3/4 inch in the rear. If your car has alot of wear and tear on it, these can actually raise it back up some. I know once I got mine put back together and on the ground, it sat a little higher than I remembered. I don't remember the spring rates, but one of the techs at SLP could tell you.
