Rear Brake Job Time..!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Rear Brake Job Time..!!!
    1993 Firebird 3.4L
    I have been getting some grabbing and "clunking" from my rear drum brakes lately and was not sure what it was. It was coming from the right rear wheel. Yesterday I pulled the right rear wheel and brake drum and found the issue. The right rear wheel cylinder has begun to leak a tiny bit and has wet everything with brake fluid. The shoes have plenty of material left on them but they are now wet with brake fluid. As a test I cleaned everything with brake cleaner and put it back together. When I test drove it they were not grabbing any more.
    So today I ordered new wheel cylinders, shoes, speed bleeders, and a spring kit. Grand total $68 from Rock Auto.
    I should be able to get to it sometime next week.
    Re: Rear Brake Job Time..!!!
    Does anybody know what size the brake line fitting is? I forgot to check and I want to make sure that I have the right size line wrench.
    Thanks...
      Hello... Hello... Hello...
      Echo.. Echo.. Echo..
      Hmmm, I guess everyone has left...
        Well, the brakes are done. Rear brakes are such a pain in the a$$. Considering I had 156,000 on the original rear brakes I decided to change everything. The wheel cyliners were leaking pretty badly so everything was a mess.
        I changed the wheel cylinders, shoes, drums, and all of the springs.
        Before:
          After:
            Thanks...
            Oh, it is 7/16 by the way.
              Thank you I am about to do my brakes.
                Sir. Im new to this site, but it seems as if your not getting any help regarding your job. I thought this site was suppose to help out with stuff like this.
                  Looks alot better , should upgrade to discs if you get a chance , one of the best mods I did to my 96' with drums. I just did mine with R1 concepts drilled slotted and ceramic pads and looks alot better , but too cold to paint the calipers which sucked.
                    how much did that cost you nascar??
                    I bought a whole rear end with disk brakes/posi/3.42 gears for 200$ and i bet you the install time took less than it did for you to keep those crummy drum brakes on there lol
                    with that being said you did clean them up nicely and you should see a nice improvement in braking now after your routine maintenence is completed.
                      I wouldn't call them crummy since you can get the ALM. drums that weigh alot less but discs look alot better.
                        do you know how much aluminum drums cost??!!
                          You would have to find them used, there was a post on them on ftv6.
                            sorry man I did my rears over the summer, but I couldn't remember the fitting size...didnt wanna give you wrong info taking a guess on it...
