32mm sway bar - FirebirdV6.com/CamaroV6.com Message Board
32mm sway bar
  • 32mm sway bar
    Alright so i ordered my 1le sway bar on ebay about 2 days ago and its already here. The best part about it is its bran new, never been used on a vehicle, and i only paid $35 for it. $50 with shipping. Ill have to get a bigger swaybar link set so i will probably mount it this weekend.
    Re: 32mm sway bar
    worrrrd? where'd you get that from? sweet find at that price and condition.
    pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
    gone in body, but not in spirit
      Re: 32mm sway bar
      I found it on ebay. I just typed 1le sway bar in and this guy K57J was selling it. I think he might have more than one cause ive seen it up there numerous times.
        Re: 32mm sway bar
        noted. i'm about to pick up a 32/21 combo and some new bushings soon --- definitely will look for this deal.
          Re: 32mm sway bar
          what else do you have done to your suspension?? sway bars/tq arm/aluminum ds is all i have left on my to do list
            Re: 32mm sway bar
            I've got springs, 1le sway bar on the back, and I'm ordering LCAs and PHB probably 2 nite. I'm wondering if the stock sway bar brackets will go on the 32mm, the rear wasn't An issue because it came with my rear end.
              Re: 32mm sway bar
              You can use the stock ones,get yourself some Moog poly endlinks though.
                Re: 32mm sway bar
                Thanks bud. Guess I'll have to order the endlinks. No one sells them around here.
                  Re: 32mm sway bar
                  You DO NOT want a 21mm sway bar in the rear!! Too much oversteer! There are tons of threads regarding this. Even GM stopped after one year. I have a 35/19.
                  Raven
                    Re: 32mm sway bar
                    Well I also have a 19 mm bar so if I run into anything I don't like I'll switch it. And I think I'm goin to stick with the stock endlinks for now, they were replaced like 10 years ago and the are still really hard.
                      Re: 32mm sway bar
                      I have a 32mm /21mm combo which works well for me since I have less weight up front and more weight in the rear along with stiffer adj. shocks and spring setup. Its a geat for striaght line and I haven't had many problems with steering except I need a new rack & pinion which is going in this next week a FE2 14.4:1 ratio bye bye rag joint. I got moog tieend rods and royal purple steering fluid ready to go in with the rack. Also doing all the wheels with new rotors and ceramic pads and earls brake lines.
                        Re: 32mm sway bar
                        So the 22mm rear sway bar from UMI is way too big then?
                          Re: 32mm sway bar
                          That's almost too big for some LS1 suspension setups. Definitely more than you'll need or want for a V6 car.
                          '99 Camaro
                          '04 Saab 9-3 Aero
                          '90 Audi Coupe Quattro
                            Re: 32mm sway bar
                            When I ran the ST 35mm front and the 21mm rear the steering was just about perfect , could hold alot of mph in the turns. But the ST 35mm is 34LBS and the 32mm hollow is 11LBS so its a nice weight reduction.
                              Re: 32mm sway bar
                              I have the 32/21 1LE and don't have any problems with it..
