Finally got them installed with help of Meatyshells(thanks again) , The rear QA-1's needed to be modified , the bolt is bigger than stock size(finally found my air grinder bits) and it went quicker. Now I have front and rear QA-1's front set on 5 and rear on 7 they handle very well and look very good(My Blisteins were bad so it mad a big difference). FE2 rack & pinion is alot better the rag joint was shot on my other one sso the knuckle setup and the 14:4 ratio is better, need to get it alligned bad though then I'll give it a real test drive.
Rear QA-1's installed/ FE2 rack
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Rear QA-1's installed/ FE2 rack
Originally posted by ssms5411 View PostFinally got them installed with help of Meatyshells(thanks again) , The rear QA-1's needed to be modified , the bolt is bigger than stock size(finally found my air grinder bits) and it went quicker. Now I have front and rear QA-1's front set on 5 and rear on 7 they handle very well and look very good(My Blisteins were bad so it mad a big difference). FE2 rack & pinion is alot better the rag joint was shot on my other one sso the knuckle setup and the 14:4 ratio is better, need to get it alligned bad though then I'll give it a real test drive.
I wish I had $500 fo a nice manual rack setup. But bye,bye rag joint. LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I got my car allighned today , they did a outstanding job, but they are saying their might be something wrong with the pump inside of it(bought it remanufactured so it was all upgraded with brass and not alm. sliding pin and other features, the Co. I bought it from has a good rep), and I feel that it is fine. I have no problems with it , no leaks, no noise and it turns really well. I'm thinking they don't have too man 14:4.1 steering ratios in there , so it feels different to them. Any suggestions/ Comments? Thanks Steve08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 weeks ago
