I haven't seen that type before, I think my BMR tubular mount to the LCA then need welded towards the front of the car. I don't see the holes for the LCA's unless they are different and are welded on both sides. But I drilled mine and made them bolt in and then welded them in and then just welded the bolts so they would be there for good. Made it alot easier to bolt them in and then weld them. Since most exhaust shops won't touch them unless they are bolted in do to liability of them coming loose and causing a accident. So I had to do mine.
