I am going to look at these wheels tomorrow. I will be buying them on the spot if they are as good as they look. I don't care about the tires. Will they fit my 1993 Firebird without any hub issues? I have heard that the 98+ have an issue with the earlier hub, but these I believe are ok.
Also, will they work with the same conical OEM lug nuts?
"Chrome wheel interference problems on 93-96 F-bodies : Chrome wheels will not fit on rear of 93-95 Firebirds due to a lack of clearance between the wheel hub and the rear axle shaft. Factory 93-96 axle shafts have a 70.75 mm diameter hub face, while the 97-02 Chrome wheels have a 70.5 mm diameter hub opening. Minor grinding/machining is mandatory for installing those wheels on 93-96 models."
Yes, I have read that on their site. These wheels are not chome. They appear to be 95-97 according to the TA Creations site. I am still not really sure...
If the rears are tight just grind the hub down, I found out the hard way.LOL But after gringing they work perfect with newer rims. Those do look like 96 style rims.
Those look like the standard 98+ wheels, like mine.
As far as the tires: it looks like someone put tire dressing on the treads - you might want to clean that off before using the tires.
There was a hilarious thread years ago about a ricer who put tire dressing on all of the surfaces of his tires and then had trouble controlling his car.
I solemnly swear I am up to no good.
2008 Saturn Sky Red Line - Midnight Blue Pewter Mafia - 2000 Firebird - SOLD CENTRAL FLORIDA KNIGHTS!!!!!!! FLORIDA STATE SEMINOLES!!!!!!!
