I has them, 315/35/17 Mickey Thompson ET streets
New tires
Re: New tires
They look good but why E.T streets instead of M.T. drag radials. Just my opinion but you should of dynoed to see how much power your making then see what size drag tire to run, unless they are just for show becuase they are going to slow you down because of the rotational mass. There are LS1's with 400 WRHP that will run a 255 M.T. Drag radial and still cut 1.6 60 ft. times. Plus if you DD on those ET streets they are not good in the rain and are unsafe just to let you know. The M.T. Drag radials are the ones for everyday use but still need to be safe in the rain. Are these just for track?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: New tires
Originally posted by ssms5411 View PostThey look good but why E.T streets instead of M.T. drag radials. Just my opinion but you should of dynoed to see how much power your making then see what size drag tire to run, unless they are just for show becuase they are going to slow you down because of the rotational mass. There are LS1's with 400 WRHP that will run a 255 M.T. Drag radial and still cut 1.6 60 ft. times. Plus if you DD on those ET streets they are not good in the rain and are unsafe just to let you know. The M.T. Drag radials are the ones for everyday use but still need to be safe in the rain. Are these just for track?
Are those not bias ply tires? I know my ET streets are...they say you should not be mixing bias ply tires with street radials as well...just FYI (although I do mix them at the track, I have just been told to be careful)
Re: New tires
I forgot about mixing the 2 types of tires also good call , thats why I like the M.T. Drag radials. I have had M.T. streets before which Meatyshells used since they were the wrong height for my front Prostars I bought off of Pathogen.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: New tires
hmmm. they might be mt streets not for sure
i had this exact pair in 275.40/15 and they were amazing
way better than nittos, and traction in the rain wasnt too bad
i got them for 40$, so i couldnt help it, the last tire i got had less tread than these and it lasted a long time
Re: New tires
Originally posted by Blizzard242 View PostNot yet, but soon yeah it will have a lsd. I'm also on 3.08 gears blah.
And actually, I've had no problems with my tires. Over the stock tires these are amazing.
Re: New tires
Originally posted by Fondle View Postyour car doesnt have posi?
i have driven a few cars with nittos and i just feel they are nothing compared to the grip you can get from a Mickey
Those should look BA on your car.
Re: New tires
Those actually look like M.T drag radials , since my 275/40/17's look like that, which they would be actually better for ya. The E.T. streets I had just had 2 grooves around the tire.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: New tires
I hope you can read the description in the link you provided. MT calls both their bias and radial street tires ET streets. You provided a link and a picture to a radial tire.
ET street
http://www.mickeythompsontires.com/s...?item=ETStreet
ET street radial
http://www.mickeythompsontires.com/s...ETStreetRadial
ET street radial II
http://www.mickeythompsontires.com/s...StreetRadialIILast edited by bigbrian442; 01-25-2010, 10:31 PM.sigpic
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
