Rubbing ?!?!? - FirebirdV6.com/CamaroV6.com Message Board
Rubbing ?!?!?
  • Rubbing ?!?!?
    I have chrome Z06 replica wheels , I have 17X9.5 in the front and 18X10.5 in the rear.
    My rear tires make a weird noise when I hit a bump or there is a dip in the road. I only hear it on the driver side . The DS rear tire is 275/40/18 . And the PS rear tire is 275/35/18. I have a feeling the tire isn't low enough. How can I fix this ? Is the problem my rear bump stops ? If so what do they look like ?
    Re: Rubbing ?!?!?
    10.5" in the rear? Time to get those fenders rolled.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      Re: Rubbing ?!?!?
      ^^ most likely. You can do a visual check for where exactly the tire is hitting, and if you don't see any wear, you may want to do a visual check of your bump stops. 275 is skinny enough not to need rolled fenders generally, but with 10.5" wheels, you'll likely need to get them rolled.
      Moving to suspension.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        Re: Rubbing ?!?!?
        you have 2 different sized tires in the rear? wouldn't that f up your driving?
        i doubt its your bump stops even though they do seem to fall apart pretty easy, both of mine are gone and it isnt a problem unless i have people in the back seats.
          Re: Rubbing ?!?!?
          I bet its rubbing on the inner fenders against the frame. If you pull your left rear off you will probably see one or two shiny spots where it is rubbing. Turning two diff diameter tires can mess up your differential if you have posi; not sure about lsd though. An adjustable panhard rod may get you where you need to be without rubbing the fenders anymore.
            Re: Rubbing ?!?!?
            I have different sizes because it was an extra tire I had just to get me going till I can replace it with the correct size. My bump stops are gone , and there are no shiny spots . I never had this problem before are yall sure I need my fenders rolled ? What is that any way ?
            Edit : I looked and couldn't see where the tire was hitting . Could it be my shox ? They have 186,XXX miles
              Re: Rubbing ?!?!?
              Could you better explain this noise for us?
                Re: Rubbing ?!?!?
                it sounds like like a loud thud and scrape at the same time haha I hope that helps
                  Re: Rubbing ?!?!?
                  Sounds more like you are bottoming out and hitting frame to axle. You said your bump stops are missing completely? That could very well be your problem. HerronPerformance has GM White bump stops in stock right now for $75 per set, or 40 each. You can find them cheaper, but GM White will be the best performers.
                    Re: Rubbing ?!?!?
                    Definitely get a pair of those white bump stops. I'm currently missing one and the feeling of bottoming out is one you'll never forget.
                    '99 Camaro
                    '04 Saab 9-3 Aero
                      Re: Rubbing ?!?!?
                      take off the tire like said abive. More then likely a quick visual check will show your problem. You might need some BFHing and adj. phb.
                        Re: Rubbing ?!?!?
                        I checked and there are no shiny spots. It also makes noise when I make a sharp turn but only when I turn left
                          Re: Rubbing ?!?!?
                          damn are you serious ? What are the consequences ? How long can I ride on different profile tires with out asking for trouble
                            Re: Rubbing ?!?!?
                            Check your glove box or driver door for "G80." If you don't have it, then don't worry about it.
                            Anyway, I'm 99% sure it's the lack of bump stops that's causing your problem.
                              Re: Rubbing ?!?!?
                              you need bump stops and probably an adjustable panhard bar. when i put my 275/40/17's on i had this exact same problem --- my bumpstops were destroyed and i was also getting a loud "scraping" or "rubbing" sound coming from the rear tire when i made a hard left or was cornering aggressively. all i had to do was replace the bumpstops and adjust my panhard rod and i haven't had a single problem since.
                              when i was having the problem, i could stand at the rear of the car and see that one of the rear tires stuck out further towards the outside of the car than the other --- it was only a little, but every cm counts when you have larger tires. i bet you'll be able to see this too.
                              pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
                              gone in body, but not in spirit
                                My Hptuners stop working
                                Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                                13 hours ago
                              • Money pit
                                Zzp cams
                                by Money pit
                                Has anyone used zzp gt1 cam if so is it worth the money and time
                                2 days ago
                              • thatpewterfirebird
                                2001 3800 s2 firebird
                                by thatpewterfirebird
                                4 days ago
                              • Turbo 3800 camaro
                                Where are the videos?
                                by Turbo 3800 camaro
                                Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
                                6 days ago
                                New Chevele
                                Just saw it on Facebook, looks awesome. The front and rear nice looking....
