im curious how wide i can go in the rear. im looking to go 18's in the back possibly. 17's in the front or 17's all the way around. so i need max width for all the corners. thanks!!!
widest wheel size
Re: widest wheel size
You could fit just about anything with enough modifications. The widest you can usually get without any rubbing problems is 275-285 at each corner. There are plenty of guys who run 315s in the back with minor modifications like bump stop relocation and fender rolling. So as far as wheels, 9.5 all around, or as wide as 11 in the back. And I'd recommend 17s all around, you can check my cardomain out, I have 17/18 staggard.
Hi, I just bought a set of 275-40/17 tires. What wheel offset do you recommend to make them flush with the outside of the rim? I'd like to fill up the wheel well without having to lower the car.
Thanks
mine has 285/40/17's on all 4 corners (budnick 17" x 11" wheels-dont know backspacing-bought car from friend & he had them "custom" made-& may i add, he paid way to freakin much for them which i rib him about merciliessly-haha-i'll see if i can find out more info on them) mine also has been lowered a little bit with hotchkis springs (supposed to be 1.5" lower) & my bud i bought the car from has run it hard in places like "the dragon's tail" (deal's gap) & "track days" at road atlanta & he says even after he lowered it he's never had a rubbing problem with that size tire, even when leaning hard on it-good luck & post some pics for all of us to drool over-lol!
Originally posted by Rhunadan View PostHi, I just bought a set of 275-40/17 tires. What wheel offset do you recommend to make them flush with the outside of the rim? I'd like to fill up the wheel well without having to lower the car.
Thanks
17 X 11 rims use a +50mm and a 315/35/17 tire , I might be getting 2 chrome ZR1 rims with tires for $250 , still debating. The price is great but don't know if I want to run that big or rear tire. Or might run 275/50/17's all around if the front will fit, or 275/50/17 rear and 255/50/17 front tire, should fill in the wheel gap some. You can use a tire calculator to see the diameter and width.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
