Things I learned about F-body suspension. - FirebirdV6.com/CamaroV6.com Message Board
  • Things I learned about F-body suspension.
    This post is really directed at new F-body owners, as the long time "pros" probably already know this. I just wanted to share my experience while its still fresh in my mind.
    If you recall, last summer I bought this 98 Firebird V6 auto with just 28k miles. Owned by an older couple and garage kept, I figured it was in great condition. For the most part it is, but as it turns out the rear needed some work.
    I didn't like the way the car handled some rough concrete highway that was poorly patched with black top. Hitting this 2 mile stretch made me wince as the car would act squirrely and didn't seem to follow the surface well. After having the 3.73's and Truetrac installed, things seemed to be even worse. Peel-outs gave way to severe wheel hop. Rough pavement was even worse, especially when accelerating or on turns. I was getting angry that I couldn't do measure 0-60 times due to bad wheel hop.
    First, larger rear sway bars were installed. 30mm front and later, a 19 mm rear, using poly bushings and end links all around. (OE is 28/15 mm on my base coupe) The front bar was a fantastic upgrade. The rear bar caused such bad oversteer I nearly crashed the car on an exit ramp. So the OE 15 mm bar went back in, but I kept the poly end links. That was a good thing. The car handled much better with the poly. So far, so good, handling much improved. Did nothing for wheel hop. Bars were free, but the poly bushings and end links ran about $40 or so. Best price on Energy Suspension parts I found was at Advance Auto. Call the local store, they will order the parts and you pay the online price, and you save shipping.
    In an attempt to stop the wheel hop, new KYB GR2 rear shocks (a mild twin tube design upgrade over the factory shock) were installed by yours truly. I allocated about 2 hours, but it only took about 1.5 hours start to cleanup. This made a big change. I never would have thought that the OE Decarbon rear shocks were shot after (now) less than 40K miles. The rear now follows even rough pavement well, even at highway speeds. Rough pavement on exit ramps is not a problem. The back end stays where it should, and interior noise is greatly reduced. Also a funny "bonk" sound that would happen on big bumps is gone. Guess the shocks were much worse than I suspected. Surprisingly the Decarbon shocks were still holding their gas pressure when they were removed, so the failure was probably in the valving/piston, rather than foaming oil. Really great improvement, and all for about $40 for a pair of rear shocks. Downside is the wheel hop was reduced, but it was still there.
    Next suspension upgrade was specifically to stop wheel hop. The two piece OE rubber torque arm bushing was replaced with an Energy Suspension one piece bushing. The E/S piece is poly, harder than rubber, but not as hard as the poly used in the end links or sway bar bushings. The bushing can be changed without lowering the trans, but space is tight, and it just takes patience and time to remove the single nut and chisel or grind off the riveted on OE bushing. I used a small 4" die grinder to remove the rivet on the trans mount. Tight fit, but do-able without messing up other parts. The other half comes out and can be worked on in a vice. After its all buttoned up, I was really surprised at how tight the rear felt. Funny road noise was reduced, and again, wheel hop seemed better, but still not totally gone. The OE two piece bushing, although not chewed up, appeared to have spread open, allowing the T/A movement. With the new bushing, the T/A is held tight. Funny "ringing" noises from the new rear gears were gone after installing the new bushing. Guy who did the rear said that the T/A resonates noise from the rear, making a quiet rear hard in these cars. So, again, car handles better, rough pavement is even better and quieter. Another cheap (about $14) upgrade that actually makes a difference.
    So now most of the rear parts have been replaced, and wheel hop is still present. I read where the rear control arm bushings are "hollow" or star shaped when viewed from the side for compliance and quiet ride. You can not tell what is on the car by looking. A common upgrade is to use poly bushings. I will not install poly bushings because this is a daily driver, and the poly often cause the control arm mounts to crack and fail because they are so stiff. So solid rubber bushings will be used, like on the LS1 suspension. Going to pick up a set of used LCA's that have been boxed to make them stiffer, and have solid rubber bushings to allow for flex. Hopefully this will be the final "nail in the coffin" of wheel hop, and I will be able to get a decent 0-60 time.
    Will keep you posted.
    Mark.
    PS. All the changes, shocks, sway bars, and T/A bushing were done in my garage using only a small floor jack and two heavy duty jack stands. Other than a cheap-o Harbor Freight 4" die grinder (and you can substitute a sharp chisel and hammer), all tools were just basic box end wrenches and sockets. Just be safe and use good jack stands and wheel chocks.
    Re: Things I learned about F-body suspension.
    as far as the lower control arms i went with the J&M Products (hotpart.com) lower control arm 3 piece bushing and love them gives you the best of both worlds and what was the part number on that torque arm bushing i need a new one
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      I have just about all poly bushings on my car and it rides very well. Plus I like having greseable bushings, I think I have like 20 on the car now.
        This is true for tubular or boxed LCA.
        So solid rubber bushings will be used, like on the LS1suspension. Going to pick up a set of used LCA's that have been boxed to make them stiffer, and have solid rubber bushings to allow for flex.
        Do not get boxed LCA, if it is a daily driver. Solid rubber is used on the 1LE LCA.
        Raven
          Part number is 3-1111R. Its only $11.99, I think I said 14.
            Originally posted by FirebirdGT View Post
            ...... Solid rubber is used on the 1LE LCA.
            BTW, solid rubber is the standard aftermarket bushing. I don't even think the OE hollow bushing is available aftermarket. I called Moog and they said all the f-body rubber bushings are solid, and the LCA are 1le spec.
              With subframe connectors and poly bushings do you think the brackets for the lcas would crack?
              1997 Chevrolet Camaro
              L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
                I have had poly for 10 years , BMR Chromoly LCA's and Panhard rod and the poly ends are still great , if I cleaned them up they would look new, about 5 years ago I installed relocation brackets and subframe connectors. I even have a rod end on 1 side of my frront lower A arm and feel no difference in the ride after it was broke in. My car is stock height and handles like when I had it lowered 1.5" s , the shocks and springs are setup pretty well. I get on it in the corners alot from time to time, but mostly I get on it from the stop.
                  Great info guys, especially since I am about to drop some cash on suspension upgrades (getting sick of the road noise and bumping).
                    Road noise will generally increase with poly bushings. They transmit the vibrations much better than the rubber bushing. If the OE bushings are shot, the Moog solid rubber are a good replacement.
                    This is what the OE non-1LE bushing looks like. See the hollow gap top and bottom? That is just space where the center bolt can move around in. Designed to eliminate road noise, not keep the LCA from moving under load.
                      I never noticed any more road noise, poly will last forever and not dryrot which is a plus. Also most ploy bushings will have grease fitting which is another plus. Only Moog bushings I have is lower/upper A arm bushings and tieend rods, which the tieend rods I will replace with rod ends once they where out. People complain about the ploy trans mounts but if they use the right guide IGORA's then the driveshaft allighnment is correct and vibrations will not be noticable, I found this out with a M5 and A4 both work great and no cracking trans mounts. but my whole interior is full of dead mat so with the windows rolled up its pretty quiet, even with a dynomax bullet race muffler before the axle.
                        i have all poly stuff in my rear now and its quieter than it used to be because my o.e stuff was worn out and i have those same shocks in the rear and love them but the o.e. decarbons are a stiffer shock thats y they are louder and dont handle as well because they dont have the other suspension parts to back them up. just go with poly lca bushings you will like the out come better and just get tubular lca the boxed ones are unnessisary and much more money.
                          Absolutely NOT - unless you have a drag car!
                          Boxed OR tubular w/ poly bushings are the WORST for a daily driver. It also shows a lack of understanding how a F-body rear suspension works.
                          http://forum.camarov6.com/showthread.php?t=100419
                          Raven
                            I've been doing a lot of reading about the fbody rear suspension. For some reason, some cars have bad wheel hop, others don't (my 96 v6 stick camaro did not have wheel hop at all!). But one thing is sure, lowering the car will induce wheel hop and wheel skid on heavy breaking.
                            So, just installing a solid rubber bushing like the Moog aftermarket will not stop wheel hop. The LCA needs to have the axle connection point lowered. Thats the job of the LCA relocation brackets. The lower the the LCA connects to the axle, the better the tires grip, and wheel hop is reduced. But the lower the connection point, the stronger the roll steer effect.
                            So I'm going to keep the existing bushings (will have to remove the LCA's and inspect bushing to be sure they are good) and install a set of bolt on relocation brackets. Then its a matter of road testing to see which of the two available LCA mounting holes should be used for my application.
                            I now have 40K miles, so unless something got trashed, the bushings should all be OK.
                            Update: I called UMI last night and spoke with a tech rep about their control arm brackets. Yes, the control arm brackets do increase roll steer. The lower the arm is positioned in the bracket, the greater the roll steer. If you are racing, you might want more roll steer, but for a fairly stock vehicle, more roll steer means more over steer. Their position is that for a daily driver or street racer, the over steer won't be felt until "you are really pushing the car" in turns. Also, the flatter the car handles, the less the roll steer affect is. So a nice stiff suspension helps reduce roll steer caused by control arm brackets.
                              Originally posted by Den69RS96
                              Has someone actually done a test or actually has data to prove poly bushings bine more than rubber or is this the result of one company stating that case and a few people jumping on the band wagon?........
                              Search the web, and you will find lots of info on poly bushings and bind all documented by individuals, not companies. Lots of people have installed poly, lots of people race with poly, so I believe their reports.
                              Your assumption that poly will bind less than rubber is incorrect. The rubber moves, allowing the joint to move at the odd angles created when a solid axle travels over bumps. Poly will not let the suspension pieces move, and binding is created.
                              I have a hard time believing that poly binds more than rubber........ Again, if a data can be produced to prove otherwise, I'll change my view on this, but a link to Global West website isn't enough proof for me.
                              Ok, believe what you want. Not my job to correct your erroneous beliefs, so we'll just leave it at that.
