Rotor grinding the inside of caliper - FirebirdV6.com/CamaroV6.com Message Board
  • Rotor grinding the inside of caliper
    what could cause this??
    Uploaded with ImageShack.us
    Re: Rotor grinding the inside of caliper
    I just noticed the different color scheme,is that a factory GM caliper assembly to begin with ?
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
      Looks like a stock 98+ caliper. Is it grinding at all times or is it only at a few spots in the rotation of the caliper? I wonder if it was a cheap rotor and warped or was out of round to begin with. Otherwise I'd suspect the caliper mounting brackets are somehow bent or misaligned. I haven't seen that before.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        it's stock calipers and everything on a 2000 chevrolet camaro.. this just happened out of the blew after i heard a loud bang on the freeway. Now it scrapes and I found metal scrapings by the caliper. It seems my brakes are also seized since my car is immovable.
          Could you explain the bang a little better? Did you hit anything/feel anything? Is the other side doing the same or similar thing? Can you narrow the seizing problem to one wheel?
            yes it's narrowed to one wheel.. the rotor feels a little bumpy. it sounded like a big rock hit the rear of my car out of nowhere.. I didn't feel anything but a little more resistance which kept getting worse
              Looks like the bracket that holds the caliper to the hub is bent. I would take that part off and see if its scraped on the underside (rotor side) of it. May not be a broken bolt, but it looks bent, as if its almost touching the rotor itself.
              1995 Pontiac Firebird
