Where can I pick up a set of lightweight aluminum drum brake covers to replace the cast iron?
aluminum drum brakes
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: aluminum drum brakes
Never seen nor heard of such a thing. I can't imagine aluminum withstanding such high heat for a sustained period of time like you see in braking....
EDIT: After taking a quick peek, I have seen a few instances where they have used aluminum for a drum. I have heard of aluminum rotors, but I figure those things would cool fast enough, didn't think a drum could do the same...but again, never seen them for an Fbody, most would have just switched to a disc brake rear if they really needed lighter/better braking.Last edited by Mogobs30th; 09-21-2010, 09:11 AM.1995 Pontiac Firebird
I know they were an option on GN's/T-Types. Dunno if they would even fit though. We did put them on my buddies Typhoon.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
well I was reading that they are an aluminum casting, aluminum fins, but where the brake shoe touches is cast iron...Drums are already lighter then disc brakes as far as I know...and these aluminum ones are supposed to drop another 5lbs off of each wheel (doesnt sound like alot, but think about how much money people spend to get a rim that is 5 lbs lighter )
no one sells them new though? I thought it might be an off the shelf thing I might be able to pick up?
theres a couple on ebay but they are not new they dont look bad you never know hard to tell from a picture.
http://cgi.ebay.com/ebaymotors/GNX-G...s#ht_500wt_956
http://cgi.ebay.com/ebaymotors/EL-CA...#ht_1391wt_939
But if you want lighter just swap the front to 98+ brakes that are alm. 2 piston, I have my 98+ spindles and calipers to swap on my front. I would stay with disc setup Wickedex6 had some light weight rotors on his front and ground down calipers, for the rear I would just do disc myself, but theres a post on FTv6 where some one was using Alm. drum covers. I would want the most weight to the rear.Last edited by ssms5411; 09-21-2010, 06:48 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
no way in hell I am converting to disc in the rear after working on the other car....not a chance in hell...you couldnt pay me enough lol....
I did just the rear disc brake conversion on the existing rear end - it was easy. Just use the same year calipers as the car. I used the 93-96 rears, not 98+ rears, on my 96.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by ssms5411 View PostBut if you want lighter just swap the front to 98+ brakes that are alm. 2 piston, I have my 98+ spindles and calipers to swap on my front. I would stay with disc setup Wickedex6 had some light weight rotors on his front and ground down calipers, for the rear I would just do disc myself, but theres a post on FTv6 where some one was using Alm. drum covers. I would want the most weight to the rear.
The aluminum rear drums are lighter than any of the disc brakes.sigpic
I would drop 10 lbs , then that would take care of the weight factor. LOL For the use of better braking.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
ahhh...but its 10lbs rotational mass...irrc its something like for every 1 lb rotational mass you loose, its the equivalent of taking 10lbs off the car....so try 100lbs :P
and actually it should be more...the chevy HP magazine that was suggesting this said that there test drum brakes weighed in at 13lbs and the aluminum ones were 8lbs...I weighed mine last night to be in at 16 almost 17lbs...so I think I would be looking at closer to 16-18lbs of lost rotational mass...Last edited by LETZRIDE; 09-22-2010, 03:14 PM.
Just take the drums off when you race, and put plastic covers over the rear studs. LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 day ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...3 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
