power steering delete - FirebirdV6.com/CamaroV6.com Message Board
  • power steering delete
    i have a 96 camaro and i want to get rid of it i want manual steering no pump. is this possible? my pupm is pissing fluid and its just a headache. any ideas?
    Re: power steering delete
    yes, its possible, you will just need a shorter belt
      I've wanted to do this on my car for quite some time. More for weight reduction than anything else. Anyone know how major of a difference there is between the power and manual? Obviously there will be some but how much.
      Let's flip a coin. Heads I get tail, Tails I get head.
        from what i have seen, you cant tell at highway speeds, but there is a major difference when turning the wheel while stopped, or moving slowly.
          i've had to drive mine when the ps return line blew off the resivour, and at highway speeds, it's pretty much the same. at about 15+, it's harder, and under 15, hope you have muscles so you can turn it fast enough to make the turns.
            I'm wondering then if the manual rack and pinion replacement aides this a little bit. I gots the muscles but don't want to fight my car to save a few pounds.
              believe me its not worth the 10 pounds your gunna save our power steering pump is small. our car with out ps is dangerous cause it really doesnt get much easyer even moving i lost mine for a week or so and it SUCKED!
                They have manual rack & pinions for like $500 which have a greater turning radius like 12.1 ratio.
                  They do have manual racks so yes it is possible...the lighter you make your car the easier it will be to turn it without fighting it....but here's the kicker...the manual racks have a worse steering ratio then our power racks.
                  irrc, lock to lock in a non y87 car is 2.8 turns, in a y87 car it is 2.1 turns, in a manual rack car it is around 3.8 (don't quote me, but I remember it being mid to high 3's for sure) so this means you are going to have to rotate the wheel more to get it to go where you want. Great for a straight line, crappy for everyday driving.
                  But let me know if you find a manual rack with a tighter steering ratio, I wouldn't mind deleting it myself...I hear you save much more then 10lbs, I think it's closer to 50-60...plus the added advantage of one less pulley
                    i drove it and i liked it alot better manual cause i personaly feel like i have more control of the steering. where do they sell the manual racks?
                      spohn.net sells them and a couple of other companies
                        X2 , spohn, thunder, LM performance, and they are geared for a tighter turn, and about 10lb savings, for $500 its steep. I thought bout doing it since I have my Tub. K and arms but its not that great for weight saving for the money, it can be spent else where.
                          you drove it how? with just your power steering unhooked as it is now? that is going to feel alot different then a manual rack...like I said, you are adding a full rotation to the wheel just to make a turn...it's going to feel that much looser on you.
                          PA racing I think also carries manual racks.
                            yes i drove it with the pump off. well any how itll be raced at the track so wieght is everything in a sense. its not a everyday driver so id really dont want to deal with the pump and all that. but then again 500.00 is alot and i could do alot more to the car with that amount of money.
                              What belt do I need to do the same? Sorry to comment on an old thread but idk how to post a new topic
                                5 days ago
