i have a 96 camaro and i want to get rid of it i want manual steering no pump. is this possible? my pupm is pissing fluid and its just a headache. any ideas?
power steering delete
Re: power steering delete
I've wanted to do this on my car for quite some time. More for weight reduction than anything else. Anyone know how major of a difference there is between the power and manual? Obviously there will be some but how much.Let's flip a coin. Heads I get tail, Tails I get head.
Originally posted by youngsc View PostI've wanted to do this on my car for quite some time. More for weight reduction than anything else. Anyone know how major of a difference there is between the power and manual? Obviously there will be some but how much.
Originally posted by cam98aro View Postfrom what i have seen, you cant tell at highway speeds, but there is a major difference when turning the wheel while stopped, or moving slowly.
Originally posted by cam98aro View Postfrom what i have seen, you cant tell at highway speeds, but there is a major difference when turning the wheel while stopped, or moving slowly.Originally posted by battousai View Posti've had to drive mine when the ps return line blew off the resivour, and at highway speeds, it's pretty much the same. at about 15+, it's harder, and under 15, hope you have muscles so you can turn it fast enough to make the turns.Let's flip a coin. Heads I get tail, Tails I get head.
believe me its not worth the 10 pounds your gunna save our power steering pump is small. our car with out ps is dangerous cause it really doesnt get much easyer even moving i lost mine for a week or so and it SUCKED!
Originally posted by youngsc View PostI'm wondering then if the manual rack and pinion replacement aides this a little bit. I gots the muscles but don't want to fight my car to save a few pounds.
They have manual rack & pinions for like $500 which have a greater turning radius like 12.1 ratio.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
They do have manual racks so yes it is possible...the lighter you make your car the easier it will be to turn it without fighting it....but here's the kicker...the manual racks have a worse steering ratio then our power racks.
irrc, lock to lock in a non y87 car is 2.8 turns, in a y87 car it is 2.1 turns, in a manual rack car it is around 3.8 (don't quote me, but I remember it being mid to high 3's for sure) so this means you are going to have to rotate the wheel more to get it to go where you want. Great for a straight line, crappy for everyday driving.
But let me know if you find a manual rack with a tighter steering ratio, I wouldn't mind deleting it myself...I hear you save much more then 10lbs, I think it's closer to 50-60...plus the added advantage of one less pulley
Originally posted by bwkmaro View Postspohn.net sells them and a couple of other companies
X2 , spohn, thunder, LM performance, and they are geared for a tighter turn, and about 10lb savings, for $500 its steep. I thought bout doing it since I have my Tub. K and arms but its not that great for weight saving for the money, it can be spent else where.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 96camaro3.8 View Posti drove it and i liked it alot better manual cause i personaly feel like i have more control of the steering. where do they sell the manual racks?
PA racing I think also carries manual racks.
Originally posted by LETZRIDE View Postyou drove it how? with just your power steering unhooked as it is now? that is going to feel alot different then a manual rack...like I said, you are adding a full rotation to the wheel just to make a turn...it's going to feel that much looser on you.
