my son has a 98 rs the shocks were bad I put new ones on easiest I have ever done but noticed sway bar link broke went to put new on sway bar is broke on end looking to get new one but shows 4 differen ones any ideas
sway bar
Re: sway bar
Originally posted by garretberg View Postare they all the same meaning will any for these cars or firebirds all fit
thanks
if you go the junkyard route, make sure it is off the same type of car (you will basically want a v6 camaro/firebird one)
too bad you dont live a bit closer, i could weld it up for you, i had the same problem and a nice weld round the broken spot worked great
Re: sway bar
I'd go with a 32mm/ 19mm if your going to the scrap yard to check them out, that would be a nice gain. I run 32mm/21mm sway bars nice and firm.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: sway bar
Originally posted by Rhunadan View PostI did an online search for a 32 mm sway bar in the Toronto area. Only one scrap yard had one. They're asking $65 U.S. for it. Is that reasonable?
Re: sway bar
I'm assuming since you said the shocks were an easy swap that you just replaced the rears, in which case you will want to stick with a stock v6 bar from pre 97 if the car is, and post if the car is. That is, unless you want to swap out both bars for a bit of a performance upgrade, in which case I'd go with 32/19 off an SS/WS6.
Re: sway bar
