Question about screw - FirebirdV6.com/CamaroV6.com Message Board
  • Question about screw
    Any one know whats size torque screws those are under the master cylinder?
    [IMG] http://www.houston-f-body.org/tech/shocks/Pic1.jpg [/IMG]
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    you mean Torx? should be able to buy a whole set of Torx heads for like 10-15 dollars. try a auto parts store or sears.
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
      do you have to remove the master cylinder to get your strut out? since the two bolts are under the mastercylinder and you cant really reach them?
        well I have a 3.4L so I am not 100% sure about the 3.8 but I wouldn't believe so. maybe use some extensions.
          I'm pretty sure it was a T40 head, it's been over a year since I did my coilovers though..
          I did unbolt the master cylinder from the vacuum booster. If you're careful you can move it over to the side enough to get a socket in there without disconnecting any of the brake lines.
          2001 Pewter Firebird Y87, M5
          Go Sabres!
            Yea it was a t47 and I moved it over from the vacuum booster. Thanks for the help i finally got it done!
