gonna have to hack saw em out and tap em in like i did the rears, i cant afford to buy the tool, $150 and every parts store ive went to doesnt rent it out.
gonna replace uca bushings today
Re: gonna replace uca bushings today
Good luck, take some pictures if you can so when someone else who can't get the tool either can seeWait, Is that a V6 or V8?
cant afford to have the shops press in all the front upper and lower control arm bushings and the rears...harbor freight sells this tool which was on sale today for $50 its reg $80. the front uppers went in very easy, all i had to do was tap the wrench with a hammer to snug em up. this tool will save me alot of cash.:rock:
nice job , same kit I have.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
When I replaced mine I just used a propane torch with a pencil tip flame to heat up the material around the bushings. Once they got hot enough, I could just press them out. Then I waited for them to cool back down and used some WD40 to clean up the gunk that was left over. Used some bushing grease to lube the new ones up and pressed them back in with a C-clamp. Finished tightening them down by using bolts and washers to make sure they were fully seated.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
