i broke the bolt which connects the lower control arm (front passenger side) to the sway bar, what do i need to buy, be it from thunder racing or wherever, to replace this
thanks
ian
The whole assembly is an "endlink" It should have one long bolt, one big nut, a few washers, and 4 bushings. PER SIDE.
You can buy poly bushings that replace the rubber ones, (which you can also do for the "body bushings" that hold the sway bar to the frame), but if you broke the bolt, you'll need a new bolt, or a whole new setup might be easier.
4 days ago
