brakes? - FirebirdV6.com/CamaroV6.com Message Board
brakes?
  • brakes?
    ok couple problems here... one, just got new rims, yes THAT part of it is not a problem, but now my brakes look UGLY. i want to have either slotted or drilled or whatever, i dont go to the track or anything and just basically street driving but i want some brakes that will look nice and provide good stopiing power.. OTHER problem is that every now and then my steering seems to lock up on one side... not very often but everynow and then when i hit the brakes the car pulls rather hard towards either right or left its different each time... and it pulls for a second but then it "gives up" and slows down normally and straight and everything... i dont think it is a rotor problem but i DO think i have at least one warped one (from burning out heheH) but that causes the steering wheel to shake wen im slowing down, this is a newer problem and only two things i can think of are
    1. got the PCM wet/ messed up when i took it out when i was trying to get some wire through the firewall.
    2. somthin to do with ppl at discount tires when the put on my rims....
    any thoughts????????????????????????????
    thanks a lot guys need help badly
    -Hawk<br /><br />===================================<br />Black 2001 Pontiac Firebird<br />Automatic Transmission Street Bird<br /><br /> <a href=\"http://www.cardomain.com/memberpage/550453\" target=\"_blank\">http://www.cardomain.com/memberpage/550453</a> <br /><br />\"Live like you were Dying\"
    Steering when braking = this is due to tires tracking the grooving/denting of the road. Its normal when you run wide tires and have plenty of caster.
    Rotors = can you afford nice Baer Eradispeeds? They're very pretty and would work well.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
