If i was to buy a camaro without this option, how hard would it be to install it or have it installed? Is it worth getting? Thanx
Sport Steering 14.4:1 ratio Can this be installed?
I wondered it too, I know it can be done. but I have heard different things about some years it was standard and some years it was only on Y87 cars.
any more word on which has which?-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
This is the standard ratio on the Z28 cars...as far as I'm aware only the Y87 package had this on the V6's...it's easy to swap out but having both Y87 and normal V6 cars, it isn't worth the time and money...unless you're going to road race your car and then the slightly quicker ratio is of some benefit...rp
Originally posted by carmelcarswholesale:
This is the standard ratio on the Z28 cars...as far as I'm aware only the Y87 package had this on the V6's...it's easy to swap out but having both Y87 and normal V6 cars, it isn't worth the time and money...unless you're going to road race your car and then the slightly quicker ratio is of some benefit...rp-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
[img]smile.gif[/img]
Couple posts down: http://www.camarov6.com/ubb/ultimate...c;f=2;t=003923
[img]smile.gif[/img]Matt
1998 Mystic Teal Camaro M5
If you have Y87 you've got it, if you don't then you don't. [img]tongue.gif[/img]Matt
