So, it's hard to turn. Squeals really loud when I turn the wheel all the way to the stops. And I fight it to stay in my lane when there's like a groove or something in the road. Any little thing pulls the car left or right but if there's nice pavement it stays straight.
Just wanted to double check with what you guys think before I throw any money at it. Any other possibilities that could cause some of these symptoms?
Sounds like alignment as well as power steeering problem. Might need new A arm bushings up front, if they haven't been replaced yet in a long time.
It's been doing this ever since I had the car. Before and after an alignment. I wouldn't doubt the bushings were never changed before I got the car. That sounds like a f'n blast.. ugh. I don't like front suspension stuff too much. However, I'll probably change the pump before I get into the suspension just in case. At least that's what I've been planning for awhile anyways.
Just another thing to add to the list for this summer's projects.
The lane wandering is likely due to worn steering components. I would plan on doing at least ball joints and tie rod ends when you get it aligned next.
Most suspension shops I went to for allignment, would do one since the A arm bushings were worn since it too hard to get the allignment straight with the wheels moving around.
I fixed everything in the front of my car and it still wanders in lanes. I did moog balljoints, bushings, tie ends, ls1 rack, everything short of bearings.
Thats either bad roads, allignment or bad tires.
4 days ago
