J&M Lca's - FirebirdV6.com/CamaroV6.com Message Board
J&M Lca's
  • J&M Lca's
    If you are thinking about buying the J&M lca's with the spherical bearing in one end DONT! Mine have been making loads of noise since day one. If you caint deal with alot of clunking dont get them.
    Re: J&M Lca's
    You're not talking about the poly-ball bearing, are you? ...or are you talking about the hymes jointed ones?
    Lounge Moderator
      Re: J&M Lca's
      they have a polyball in one side, which is great. And a teflon spherical (hymes) in the other, which sucks for daily driving. If you want J&M's go with poly ball in both sides.
        Re: J&M Lca's
        The dual poly-balls are amazing. Generally race equipment isn't well suited for daily driving.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Re: J&M Lca's
          They are called Heim joints, people. And mine make a ton of noise too. What do you expect when you replace a rubber bushing with a rod end?
            Re: J&amp;M Lca's
            my rod ends are quite? I got em up on the lower front A arms...just have to lube them with grease every oil change to take care of them... I did it when I installed them, and maintained so ever since...
              Re: J&amp;M Lca's
              i have had mine for over 5000 miles now just as quiet as stock check your torque..
              2001 Camaro 3.8 A4
              1991 3000GT VR4
              2001 Mitsubishi Eclipse GS
                Re: J&amp;M Lca's
                Can you buy just the poly ball? I have poly bushings in both ends of my umi lca's. If not I'm just gonna get some hard rubber for the upper bushings.
                1997 Chevrolet Camaro
                L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
                  Re: J&amp;M Lca's
                  No the guy said the bore on the bearing side is bigger than the poly ball side. im going to try and put some rubber between the rear end and the bearing and see if it quiets down
                    Re: J&amp;M Lca's
                    I'm running the dual poly balls as well. They are firm, non-binding and quiet.
                    Lounge Moderator
                      Re: J&amp;M Lca's
                      I have ran poly everything for years now,also rod ends on the front A arms and mine are quiet no problems , I just grease them every year or two.
                        Re: J&amp;M Lca's
                        yea i grease mine twice a year
                          Re: J&amp;M Lca's
                          Try the rubber inbetween them then see if it helps , maybe they need more time to break in.
                            Re: J&amp;M Lca's
                            definatley a possibility since I dont drive the car too often. But they have been up there since december of 09
