If you are thinking about buying the J&M lca's with the spherical bearing in one end DONT! Mine have been making loads of noise since day one. If you caint deal with alot of clunking dont get them.
J&M Lca's
Re: J&M Lca's
They are called Heim joints, people. And mine make a ton of noise too. What do you expect when you replace a rubber bushing with a rod end?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: J&M Lca's
my rod ends are quite? I got em up on the lower front A arms...just have to lube them with grease every oil change to take care of them... I did it when I installed them, and maintained so ever since...
Re: J&M Lca's
Can you buy just the poly ball? I have poly bushings in both ends of my umi lca's. If not I'm just gonna get some hard rubber for the upper bushings.1997 Chevrolet Camaro
Re: J&M Lca's
I have ran poly everything for years now,also rod ends on the front A arms and mine are quiet no problems , I just grease them every year or two.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: J&M Lca's
Originally posted by Watazz View Postyea i grease mine twice a year
Try the rubber inbetween them then see if it helps , maybe they need more time to break in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
