What i mean is can i use all parts off a lt1 on my v6 without having to modify anything?IE sway bar,shocks,springs and bushings.
Are all 93-97 camaro suspensions basically the same?
93-97 v6 sway bars
30/17
93-97 z28 sway bars
30/19
springs are stiffer but might bump up the noise do to the weight differnence of the motors.
shocks are the same.
Are you looking at aftermarket or stock stuff?-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
You can use everything, but the springs. If you can, get the rack and pinion off the z28 too. The z28 has a faster ratio rack unless you have the Y87 performance package then they are the same. If you have a base model camaro, the rack you would have would be the slower one.69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
