Are all 93-97 camaro suspensions basically the same? - FirebirdV6.com/CamaroV6.com Message Board
  • Are all 93-97 camaro suspensions basically the same?
    What i mean is can i use all parts off a lt1 on my v6 without having to modify anything?IE sway bar,shocks,springs and bushings.
    im 99% sure that its yes but that wond necesarily make you handle any better
    The confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
      93-97 v6 sway bars
      30/17
      93-97 z28 sway bars
      30/19
      springs are stiffer but might bump up the noise do to the weight differnence of the motors.
      shocks are the same.
      Are you looking at aftermarket or stock stuff?
        You can use everything, but the springs. If you can, get the rack and pinion off the z28 too. The z28 has a faster ratio rack unless you have the Y87 performance package then they are the same. If you have a base model camaro, the rack you would have would be the slower one.
        69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
        • Manimal
          Coil springs
          by Manimal
          6 days ago
        • Manimal
          Newby here
          by Manimal
