coil overs for handling setup(ABOVE)
I have the QA1's w/ 325# springs, and after a bit of time finding the correct adjustments, wow.. I can't even put into words what the difference is. It's like I have a whole new suspension, that was made to be under a sports car.
My Settings:
Front Compression: 8 Clicks
Rebound: 16 Clicks
Rear Compression: 12 Clicks
Rebound: 12 Clicks
Height: 1/2 Drop (approx.)<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
i was thinking of getting them to, but thats just the front ones right?
what would be a good rear set up with them?K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
did it mess with your alignment? how hard to adjust? how much did you pay!! can you adjust the height?
sorry this is kindof a dumb question but does this also replace your shocks? ow would i need some of those too?<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
Originally posted by Yaba3800:
thanks for helping me by the way. on umi.com they are for $440!!! so i take off my old shocks? what i meant by the alignment is it permanently off or can it be re-aligned? like if you lower it after aligning doesnt that mess it up? thanks
QA1 Generation F Coil-Over Kit
Kit Includes:
(2) Front Coil-Over Shocks
Generation F Series Single Adjustable Shocks (Part #OED7855P)
(2) Specially Designed F-Body Springs
325lb. Designed for a firm ride and great handling (Part #15FB325)
All Mounting Hardware
Item #: GK7325
Price: $439.99/kitThe confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
That is the front-only set though. As I said above, all four corners together, usually run around 750-800 dollars a set. Check Jeg's or Summit for pricing on a complete set.
You do not want to just buy 1/2 of a coilover suspension. Mixing and matching coils with standard shock + spring combos, negades most of the benefits. It's a waste of money. Looking at your post again, I don't think you want to do that, but I'd thought I'd mention it for those considering it. (cretins, all of you)
The alighnment and it's settings depend on the height you adjust them too. There are places on the net that you can get the proper measurements for driver weight, ride height, etc. etc. so that's no big deal really. Alighnments are far from permenant, lol.
[ September 16, 2005, 01:46 AM: Message edited by: Rabid Dog ]<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
Well, I guess you've found two things that make baby jesus cry. Or, well at least you, anyways.
How in the world can you damage a suspension playing with tie-rods and slider bolts?<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
i dunno, i was backing off the lift and i turned and it went BAM and started turning itselg when i drove. and one of my tires is stright and the other is toed left ALOT. its all fed upThe confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
