i am sure there is no easy fix for this but what can you do to stop brake squeek ? btw the rotors were cut and pads are new.
break squeek ?
Go to auto store, buy a can of Brake Squeak-Stop. It's blue silicone that you spray on the back side of the pads. Also, did your pads come with shims? My ceramic pads for the front didn't, but the rear ceramic pads did. Shims will usually stop any/all squeaks. The blue silicone spray WITH the shims will just add to the anti-squeak insurance :Dsigpic
bleed your brakes. make sure they're not too tight
they ought to be fine since they're new
you havent used up too much brake pad (theres a metal piece sticking out that you compare the pad to).
maybe check rotor size/warpage
hockeyman is right2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Did you bed in the brakes properly?Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
I have wilwoods on mine and they squeek. They came with a silicone boot, but I removed it. Maybe this is why yours squeek also???Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
