I was wondering. Between KYB or Monroe, which is recommended? Car is V6 model, and do want a good shock that will last for awhile. Thanks.:banana:
Struts/Shocks are preferred?
Re: Struts/Shocks are preferred?
I ran Bilsteins and Eibach springs on my 01 for a number of years and they worked very well. In fact, if handing performance is the goal, you want a fixed-valve shock and aftermarket spring package, the combination of Bilstein shocks and Eibach springs offers excellent performance and is a great value. The springs will lower the car 1 to 1.25 inches which is an added benefit. For more information on this see: http://www.camarohomepage.com/project/part1.htm
Just recently, I've moved on to QA1 double-adjustable shocks with Global West constant rate rear springs and Eibach coils over the QA1s DA's in front. Admittedly, a much more expensive set-up that the Bilstein/Eibach combination I ran before but, considering other suspension mods and my tire/wheel package, I needed an even better shock/spring combination.
Give Sam Strano a call from stranoparts.com. He's very well respected in the F-Body community for suspension and he'll tell you the best setup for what you're looking for. Last time I called him up, he told me that the Bilstein HD had gone through a design change and he was no longer recommending them. He recommended that I pick up the KYG AGXs, or Koni if I was willing to drop the coin. As far as springs, Strano springs are the best if you want linear springs; Hotchkis if you want progressive rate.
Originally posted by SteveGB21 View PostI was wondering. Between KYB or Monroe, which is recommended? Car is V6 model, and do want a good shock that will last for awhile. Thanks.:banana:08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by TheGr8Schlotzky View PostLast time I called him up, he told me that the Bilstein HD had gone through a design change and he was no longer recommending them.sigpic
For ride quality improvement due to worn shocks, I still recommend Bilstein HD and stock springs (which I've run) or the SLP Springs/Shocks Combo for ~$660 (which Im about to run).2002 5-spd NBM Camaro
Details: www.1lev6.com
Originally posted by SteveGB21I was wondering. Between KYB or Monroe, which is recommended? Car is V6 model, and do want a good shock that will last for awhile. Thanks.:banana:
EDIT: I assume you're talking about the AGX shocks, right? I just saw another poster mention the GR2s; if those were what you were asking about I know nothing about them.
Originally posted by DoctaIs the Eibach kit for our cars any good?
In fact, if anyone wants to try the Eibach springs I took off let me know, I'll part with them for next to nothing (+ shipping of course :D).Last edited by EarlR; 05-13-2011, 10:33 AM.
At the very least, anyone's choice when it comes to shocks on these cars (there are no struts on 4th gens) should be KYB GR2s. These are mild stock replacements and are decent for the price. Monroe and/or Gabriel shocks are auto part store stock and are worse than OEM (unless your deCarbons are blown and you're bouncing along the road). Personally, I would prefer Bilsteins to either of these, or Konis for that fact, but those are both a step or two up in budget.
My Z car came with Monroe Sensa-Traks on it's strut/shock design, and they are the worst shocks I've felt. They feel like they're not even valved properly for the stock 146/188# springs and bounce you around in the car at every bump or uneven spot in the road.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
bump.
Originally posted by Heywood View PostWhat design change exactly? I was just about to order to my bilstein HD's after reading what others on here had to say about them. Should I get something else instead? (I just want a good replacement for stock shocks at a reasonable price.)sigpic
My guess would be KYB ADJ. or Blistiens.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
