Not sure if this is a common problem.... My 00' Camaro makes some rear noise (a sort of metallic clunking) when under hard acceleration at a turn. It is especially noticable if at a stop, and I then gas it into a right-hand turn. Any idea what this could be? It only occours during the hard acceleration, otherwise the rear is silent.
If you drive your car hard I recommend changing out sway bar end links and bushings fairly regularly. I know I've worn mine down HARD before. Last time I changed the fronts I couldn't even get the washers off the from end links, they fused to the bolt... on both sides. The bolts also looked like beavers were trying to fell them (like a tree).
It was raining today so I coudlnt get under my car, but I will put it up tomorrow if weather permits, and take a look at the sway bar, bushings, and end links. If i remember correctly, the end links looked rusted up last time I had the car up. I wouldnt be surprised if theyre about to give up the ghost...
So it looks like my sway bar is fully intact, however as you guys said, the bushings are pretty old looking; somehow forgot to look at the end links. Ill prob be able to replace them in about a month or so when I have access to my neighbors lift again. In the meantime, do you guys recommend anything to grease the bushings with?
