Jeep question - FirebirdV6.com/CamaroV6.com Message Board
Jeep question
  • Jeep question
    I know, I know, it's not an Fbody, but I am hoping you guys might have some thoughts.
    My wife has a 2000 Cherokee sport. When I hook up our pop-up camper, and load the thing up for campiing, it sags something aweful. The leafs actually bend the wrong way, and it occasionaly bounces off the bump stops.
    I installed a set of Rancho RS9000 adjustable shocks, and on the stiffest setting, it helps some.
    What do you think, a full set of higher grade springs, or maybe just an add-a-leaf? I saw some weird leaf thing that was suppose to prevent this, but I idd not recognize the company (I forget the name now). It was like a spring on a ball that moved based on the load.
    Any thoughts are appreciated.
    I helped a guy put some helper springs on a work truck with full steel tool boxes. They helped the sagging problem.
      www.jeepforum.com
      stiffer springs would help but i dont think add a leaf would of the same caliber
      2000 3.8 A4 Pewter Camaro
        Well I am a Jeep guy first and recently picked up my Camaro as a daily driver while I completed the Jeep project.
        The best thing for you to do would be to get new springs, or at least look around for a set from someone who installed a lift recently.
        Is the Cherokee stock height? If your interested in doing a lift on it let me know I have a ton of hook-ups on discout pricing.
        Dirk
        88 RS V6 DD<br />96 Jeep Grand Cherokee Limited as my toy.<br /><a href=\"http://www.4x4oil.com\" target=\"_blank\">http://www.4x4oil.com</a>
          The Cherokee is stock height. Stock everything except for the shocks. I don't want to lift it since it is my wife's daily driver.
          I loath the idea of doing springs again. I did them in my old YJ - took days and like 20 sawzall blades.
          I will probably farm out the job and get a new set of high perf springs. Any suggestioins on brands?
          Thanks for the replies.
            Let me do some checking around today and see what I can come up with.
            Dirk
              Give Quadratec a call at 1-800-745-6037
              They should be able to get you some OEM replacements for about $60 each.
              Wish you were closer I could do the work for you in no time.
                Are OEMs really going to help? You think my springs are worn? I was thinking the springs it came with were just wussy - to make the cherokee ride better.
                I could tow 3000lbs with my old Wrangler with zero sag whatsoever.
                do the work in no time? What technique would you use? I assume not sawzall - that took me a while.
                I use to get Quadratec catalogs all of the time - I ordered tons of crap for my Jeep.
                  I am thinking that your springs are just worn, if not then you might have to go with a small lift in the back to get stronger springs. Rubicon Express would be a great option, their springs are great. I recently installed a set of 4.5" lift springs on a 90's XJ and they were beefy.
                  You are right it might take a little work to get the springs out, but it is not that bad really. Sawzall and a BFH usually work out pretty good. Or you could always bust out a torch.
                  If you want you can contact my friend Nick at kolak@aol.com tell him Dirk sent you, he has GREAT prices on all kinds of stuff.
                    Replacemento spring are exspensive, I'm assuming leaf packs. Get a set of heavy duty springs through 4 wheel parts for 350+.
                    255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
                      I am not sure what a leaf pack is.
                      I was thinking of getting a set of heavy duty springs ( I will check out 4 wheel parts and quadratec). A place around here will do the install for $300. Given how long it took me on my YJ, I think $300 is worth it to have it done there.
                      Thanks for the input.
