I put the V8 kit on this weekend. Also did Koni shocks at the same time.
The front was slightly higher than the rear. The Koni shocks had a second (lower) notch for the lower spring mount, so I moved it down to that lower notch. Now the car is level.
I went from three fingers between the tire and fender, to one finger... However much that is... Right at 1.5" I believe.
The car is MUCH firmer. The rear is almost too stiff. Will be autocrossing it this coming weekend, and I'll know more then. It feels like it will slalom much better.
