Vacuum for braking - FirebirdV6.com/CamaroV6.com Message Board
Vacuum for braking
  • Vacuum for braking
    Ok, so I have begun looking into solutions for my braking issue. With this cam that I have, I dont think I am building enough vacuum for proper braking...I.e, if I pump the brakes 1-2 times before coming to a stop (like a gradual slow down on a main street, and apply a little more pressure each pump) by the time I hit the brake the 3rd time it's like I have manual brakes, very hard to get the car to stop. It's the worst in stop and go traffic, but normally the first 2 pumps it stops good.
    So I have been toying with adding an additional vacuum reserve like this one http://cgi.ebay.com/ebaymotors/Chrom...Q5fAccessories
    but does anyone have any experience with these? I mean how well would something like that work for me?...or should I look into ripping something off of a diesel car (because they dont have vacuum) and adapt their pump to our cars and use that for my braking?
    Re: Vacuum for braking
    Have you properly bled the brakes recently and not let the master go dry?
    Also, you could look into hydroboost instead.
      How much vacuum do you have at idle?
        vacuum canisters work great.. im going to get one once i get power brakes
          Whats your vac. running?
            Brakes are bled properly...this has been an issue since the new cam/motor went in...I dont know what my vacuum is at idle, I dont have a vac gauge...and I have replaced my check valve to make sure that wasnt the issue...I think its just because the cam is much bigger...
              You need a vac. gauge to see what it is running.
                I say buy the vacuum tank Mike. If it doesn't work for you ,(I think it will) I'll buy it from you. Its a common problem when using a very lumpy cam.
                  lol i know you were mentioning that to me. How do you hook one of these things up anyways though?
                    If the can has 2 nipples (hee hee hee), then cut a vacuum hose in half and connect both ends to it.. If there's only one nipple, use a TEE fitting to splice it in or find a spare vacuum port somewhere and plug into that.
